By 92convert
#10273
Is there a way that I can save this engine block ? Hair line crack between cylinders.
By fireflyse
Custom Custom Avatar
#10274
No, but it is not important as any block before 1994 can be used. Just make sure the block you use has the bosses for the oil return and knock sensor.
By fireflyse
#10279
Rageous wrote: Sun May 16, 2021 2:15 pm
If you are looking for a NOS turbo short block
I have one but it’s going too cost you more than an arm and a leg. :party:
Please check your private messages.
By 92convert
#10281
Thx for all the replies.
I have 3 good turbo short blocks plus this crack block and 4 regular g10 blocks. Just try to salvage that one and don’t want to throw it away. It’s getting harder and harder to find just a regular metro, firefly, and forsa parts .
By fireflyse
#10402
@Rageous please check your inbox
Вызов стоматолога на дом стоматология недорого […]
pontiac truck
water pump leak. :-( engine oil leak :-( water p[…]
92 Black GT
I put down the dynomat and test fitting the brand […]
87 Turbo shell
how is it for rust? Can I see the floor pan?
