- Tue Mar 21, 2023 12:54 pm
#14801
I’ve owned 3 convertibles and two hatchbacks in the past 15 years and I used to be active on teamswift. I’ve been lurking here, but just made an account today.
Picked this bad boy up in Dec for only $1100. It needed brake lines and a new top.
Replaced the top first in a day and
upon further inspection I ended up replacing both rear brake lines, fuel lines all the way to the tank, fuel filter, timing belt(I was able to rip the teeth out with my fingernails) valve cover gasket, distributor gasket, water pump,
Mod so far was I cut the a/c pulley part off the crankshaft pulley which saved about 1.2lbs of weight off the pulley.
I also installed the tallest 13″ tire I could find(westlakes)
Unsure of MPG because I just started driving it and I have not gone through a tank yet, but been doing low 70’s highway and I can feel the car dragging…so
I am working on making a front damn cover in CAD that will clip on to the front bumper to block half of the air dam and I am going to make a rear bumper belly pan for starts
Buffed the car and this is how it sits now. Oh and the 15″ subwoofer is counterproductive to my mpg goals, but it was in most of my geo’s so that’s fun for me :D
Walt, blueturbofly liked this
