I made a mistake running the Emergency brakes up instead of down. Meaning the emergency bracket can be flipped to point down or up. I didn’t see the clearance issue when I was test fitting, and down I would lose the rear brake bracket. Turns out that I cannot use the bracket anyways since I have to run the brake line on the other side of the strut. I was also thinking the emergency brake line would install better in the other position which is true, but is far better choice to run the bracket down. Hein sight is 20 20. That forced be to cut into the rear inner tub about 4″ up to allow for travel clearance. I believe if I would have installed reverse I would not have had to do that. At some point I will go back in and run weld bead at the bottom edge of the cut to strength it. Emergency lines are already cut to length. I might be possible to re-mount the inside to get it to work, but the cut is already made.
The right rear the emergency brake braket holder broke when I was trying to fit the Lokar fitting inside it. Fucking Lokar. I like Summit Racing but they never called me back to arrange for me to get the right parts. I simply modified and installed for right rear. This was another learning experience. Ideally the emergency bracket should be redesigned to fit on the inside and not between the caliper and the disc. I got them to work but the clearance was tight and it makes the install a lot harder since you have to take the caliper facing off to tighten bolt then install inner pad, rotor, outer pad, and then caliper facing.
The rear system is working pretty well and I believe the stopping distances are quite a bit shorter. It is a longer pedal feel. This next summer I will switch out the brake booster for a new one to see if that has any effect on the pedal distance. The cool thing is that it is a much more control lock up from 60 to 0. In fact there is a lot less lock up involved where there is more control in the pedal before lock up and even if I jam on the brake it slows down the speed of the vehicle more quickly before full lock up. I guess a better way of stating it is that it is harder to lock up the brakes yet the stopping distances are decreased. I will have to do some testing to see where I’m at.
