#9946
Instant_shine wrote: Fri Feb 26, 2021 8:07 am
Nice work man! ;-)
Thanks. I really want to see what it will do with a better turbo. I cannot believe that I’m running essentially a $120 brand new turbo with it. I bought a new IHI RHB5 vj11 CHRA from Europe. So far it has worked great, but there is turbo lag that I want to do away with.
By gt4tified
#10337
Good stuff! Any updates as to the new turbo? Is there any other design option besides a full blown manifold? I’m thinking about building a turbo G13b DOHC engine on the ground just for the heck of it. Not gonna do anything crazy. Looking to run possibly a T25 turbo off a Nissan Silvia/ 180SX. No more than 15psi with good tuning. Any advice will be welcomed.
#10344
The wastegate was causing the turbo lag. It is 30 + years old. Most T25 will work comfortably with not much upgrades to the fuel system.
gt4tified liked this
By gt4tified
#10348
Are you aware of any direct OEM injector upgrades from other applications? I’m not even sure whether the stock GTi injectors are high or low impedance. Sheesh.
By Miniswift
#10357
Gti OEM Injectors are low impedance and 260cc/min.
You can use either Toyota Supra or mitsubishi Evo 6.
I think they are like 360cc and 480cc something like that and they are low impedance.
By gt4tified
#10362
Well if Supra injectors (550 cc) work, then the 5th Gen. Celica injectors (440cc) will as well! And I just happen to have a set of those lying around! Thanks!
#10363
One of my goals was to not increase the injector size and reliably tune my GT turbo. All I have is a Walbro 255 fuel pump, turbo chip and with the Vitara Honda piston with lower compression.
I haven’t needed bigger injectors up to probably 200 hp at the wheels. I am going standalone shortly and will get a lot more control before I go up a size of turbo chargers from a 52 mm to a 58 mm with just a slight increase in compressor wheel measurements. I will likely have to increase injector size at that point. The T25 I looked at were all under 52 mm.
Walt, gt4tified liked this
#11098
Manifold update:
I had to take apart and have the manifold welded again. I have it all back together with a ⅝″ rise in the t3 flange. This provided all kinds of extra clearances almost everything. The only exceptions were: one of the bolts for the metal heat shield (this just needs to be installed before attaching the whole unit), and underneath the front cross brace ( I rounded the thin metal up as and arc). The oil hoses, lower turbo mount, intercooler hoses all have better clearances.
#12087
Thanks. I don’t care to do another one any time soon, but certainly learned a lot about welding and manifold construction.
Вызов стоматолога на дом стоматология недорого […]
pontiac truck
water pump leak. :-( engine oil leak :-( water p[…]
92 Black GT
I put down the dynomat and test fitting the brand […]
87 Turbo shell
how is it for rust? Can I see the floor pan?
