- Wed Dec 08, 2021 7:45 am
#12071
for having 4 inches of snow, not really busy.
steady, but not overwhelming like last year…
seems like the relics are coming out to get fixed….i mean pre 80’s era snowblowers
but, they still work, so people want them running…
one has an oil leak from the case….needs new case gasket…farmer says remove gasket, use rtv to seal it…umm…but dont spend over 1 hour labor on it…
guess what? you CANNOT use straight sealant on the case halves, the gasket also determines the crank end spacing…BUT farmer says to remove gasket and install permatex….so i did.
ENGINE WAS LOCKED UP SOLID !!!
would not turn over by hand….loosen case bolts, engine turns…whadda ya know….
there are 3 different gaskets; 5, 9 & 15 thou thickness….i need the 15 thou gasket.
so, call customer, tell him the issue, that HE NEEDS the gasket…so he finally lets us order one.
that was 4 + hours of my day wasted…for a customer trying to be cheap….
and i still need to assemble engine (when parts get here), attach to frame, install carb, pulleys , belts and guard… already made him a custom carb gasket…that was almost an hour right there…
thats why i dont want to be in business again….i am happy being an employee, and let the boss deal with the ignorant people.
