I got to get some pictures of the interior. It came out pretty nice. I got in today the Aasco ligtht weight aluminum flywheel. Rough weigh in at 6.4 lbs. Lighter then I was thinking. I’m planning on getting a Spec 3+ clutch to go with. The Centerforce dual friction clutch doesn’t hold above 14 psi with my setup and I have to feather the throttle at that point. The Spec 3+ clutch should hold up to 280 hp. I also think the Centerforce clutch with the weights rattles to sh*t at high enough rpms.
SPEC Clutch Stage 3+ The flagship stage for a high powered street or race car that requires a manageable and friendly engagement, the stage 3+ features a carbon semi-metallic full faced material that offers unparalleled life, friction co-efficient and drivability characteristics in one single package. The sprung hub (application dependent) version is double sprung with spring cover relieves for flexibility and heat treated components for strength and durability. Great for street, drag, drift, autocross, road racing, pulling, rallye and drift. Some applications require a solid hub based on the vehicles flywheel setup.
SPEC Maximum Torque Recommendations (Measured at the Flywheel):
Stage 1 Stage 2 Stage 2+ Stage 3 Stage 3+ Stage 4 Stage 5
Kit Part Number: SC001 SC002 n/a SC003 SC003F SC004 n/a
Torque Capacity: 150 190 240 280 240
Stage 3+: Street, Drag, Pulling, Autocross
The flagship stage for a high powered street or race car that requires a manageable and friendly engagement, the stage 3+ features a carbon semi-metallic full faced material that offers unparalleled life, friction co-efficient and drivability characteristics in one single package. The hub is double sprung with spring cover relieves for flexibility and heat treated components for strength and durability. Great for street, drag, drift, autocross, road racing, pulling, rallye and drift.
This article provided me with my choice for clutch:
https://www.streetmusclemag.com/news/cl ... -weigh-in/
